Téma: Olej Yamaha PW-50
28.1.2024 v 13:36
Ahojte, jaký olej se prosím leje do motorky Yamaha PW-50? Nemyslím do benzínu. Na netu jsem našel různé označení, tak si nejsem vůbec jistý. Děkuji.
Olej Yamaha PW-50
28.1.2024 v 14:03 | Nahoru | #1
MÁŠ TO TADY V MOTOKATALOGU
PECIFICATIONS
EAU2633X
Dimensions:
Overall length:
1245 mm (49.0 in)
Overall width:
575 mm (22.6 in)
Overall height:
715 mm (28.1 in)
Seat height:
485 mm (19.1 in)
Wheelbase:
855 mm (33.7 in)
Ground clearance:
105 mm (4.13 in)
Minimum turning radius:
1300 mm (51.2 in)
Weight:
With oil and fuel:
39.0 kg (86 lb)
Noise and vibration level:
Noise level (77/311/EEC):
PW50 75.1 dB(A)
Vibration on seat (EN1032, ISO5008):
PW50 Will not exceed 0.5 m/s 2
Vibration on handlebar (EN1032, ISO5008):
PW50 Will not exceed 2.5 m/s 2
Engine:
Engine type:
Air cooled 2-stroke
Cylinder arrangement:
Forward-inclined single cylinder
Displacement:
49 cm3
Bore × stroke:
40.0 × 39.2 mm (1.57 × 1.54 in)
Compression ratio:
6.00 :1
Starting system:
Kickstarter
Lubrication system:
Separate lubrication (Yamaha autolube)
Engine oil:
Type:
YAMALUBE 2 or 2-stroke engine oil (JASO
FC grade) or (ISO EG-C or EG-D grade)
Engine oil quantity:
Quantity:
0.30 L (0.32 US qt, 0.26 Imp.qt)
Transmission oil:
Type:
YAMALUBE 4 (10W-40) or SAE 10W-40
Oil change quantity:
Air filter:
Air filter element:
Wet element
Fuel:
Recommended fuel:
PW50 Regular unleaded gasoline only
PW50Z Regular unleaded gasoline only
(CAN)
PW50Z Unleaded gasoline only
(AUS)(NZL)
Fuel tank capacity:
2.0 L (0.53 US gal, 0.44 Imp.gal)
Carburetor:
Type × quantity:
VM12SC x 1
Spark plug :
Manufacturer/model:
PW50 NGK/BPR4HS
PW50Z NGK/BPR4HS
DENSO/W14FPL
Spark plug gap:
0.6–0.7 mm (0.024–0.028 in)
Clutch:
Clutch type:
Wet, centrifugal automatic
Transmission:
Primary reduction system:
Spur gear
Primary reduction ratio:
63/33 (1.909)
Secondary reduction system:
Shaft drive
Secondary reduction ratio:
19/15 × 54/11 (6.218)
Chassis:
Frame type:
Steel tube backbone
Caster angle:
25.50 °
Trail:
50.0 mm (1.97 in)
Front tire:
Type:
With tube
Size:
2.50-10 4P
Olej Yamaha PW-50
28.1.2024 v 15:55 | Nahoru | #2
Zjednoduším ti to - stejný, jako do motoru tvojí Z800.
motorka pro 4. letého kluka Yamaha PW 50, Honda CRF 50F Hondzik78 4 4.8.2015 v 12:50 Hondzik78
přídavná kolečka NA MOTO Yamaha PW 50 250 27 4.4.2015 v 17:01 kleiny
prosím o radu Yamaha PW 50 250 2 16.2.2015 v 20:18 250
